Hi, www.grovestreams.com is a service that will graph your devices and let you build a dashboard.
Here’s my SmartApp, adapted from @florianz ThingSpeak app to let you connect your devices to GroveStreams. You’ll need a free account first, when your create one it will prompt you for an organisation name - you can enter something like “Home”. Once you have created your organisation you need to get the “Feed PUT API key”:
It’s long… you might want to email this to your phone so that you can cut and paste it into the ST app.
The SmartApp uses the device name as the “Component” in GroveStreams and the capability attribute (e.g. “temperature”) becomes a “Stream” in GroveStreams. These will be auto created so you don’t need to set them up in GroveStreams. However, once they have been created you may want to edit them (by right-clicking the Component) to set things like the type (e.g. “Boolean”) and the units (e.g. “Yes/No”).
Here’s the SmartApp, let me know if you have any problems
* GroveStreams
* Copyright 2014 Jason Steele
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
namespace: "JasonBSteele",
author: "Jason Steele",
description: "Log to GroveStreams",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("Log devices...") {
input "temperatures", "capability.temperatureMeasurement", title: "Temperatures", required:false, multiple: true
input "contacts", "capability.contactSensor", title: "Doors open/close", required: false, multiple: true
input "accelerations", "capability.accelerationSensor", title: "Accelerations", required: false, multiple: true
input "motions", "capability.motionSensor", title: "Motions", required: false, multiple: true
input "presence", "capability.presenceSensor", title: "Presence", required: false, multiple: true
input "switches", "capability.switch", title: "Switches", required: false, multiple: true
section ("GroveStreams Feed PUT API key...") {
input "channelKey", "text", title: "API key"
def installed() {
initialize()
def updated() {
unsubscribe()
initialize()
def initialize() {
subscribe(temperatures, "temperature", handleTemperatureEvent)
subscribe(contacts, "contact", handleContactEvent)
subscribe(accelerations, "acceleration", handleAccelerationEvent)
subscribe(motions, "motion", handleMotionEvent)
subscribe(presence, "presence", handlePresenceEvent)
subscribe(switches, "switch", handleSwitchEvent)
def handleTemperatureEvent(evt) {
sendValue(evt) { it.toString() }
def handleContactEvent(evt) {
sendValue(evt) { it == "open" ? "true" : "false" }
def handleAccelerationEvent(evt) {
sendValue(evt) { it == "active" ? "true" : "false" }
def handleMotionEvent(evt) {
def handlePresenceEvent(evt) {
sendValue(evt) { it == "present" ? "true" : "false" }
def handleSwitchEvent(evt) {
sendValue(evt) { it == "on" ? "true" : "false" }
private sendValue(evt, Closure convert) {
def compId = URLEncoder.encode(evt.displayName.trim())
def streamId = evt.name
def value = convert(evt.value)
log.debug "Logging to GroveStreams ${compId}, ${streamId} = ${value}"
def url = "https://grovestreams.com/api/feed?api_key=${channelKey}&compId=${compId}&${streamId}=${value}"
def putParams = [
uri: url,
body: []
httpPut(putParams) {
response ->
if (response.status != 200 ) {
log.debug "GroveStreams logging failed, status = ${response.status}"
