I purchased the GoControl Z-Wave battery powered thermostat today and am struggling to integrate it. My current thermostat is a Honeywell RTH7600 and works fine, but we would like to have a thermostat that we can adjust on the fly.
I connected it as the directions provided but I only get cold air. I then did some online research and tried a few other wiring configurations and each time the fan would come on but never the heat pump.
The Facts:
4 Wires: Red, Yellow, White, Green
R and RC are jumpered
I have no C wire, hence, why I needed a battery powered device
Does anyone have any idea what I am doing wrong? I feel like it’s something really simple and stupid I am overlooking or doing wrong. Figured I could use some good eyes to double check.
A gas furnace should be wired that way. If your AC turns on but not the heat check the jumper between the red wire and Rh. You should have a jumper between Rh and Rc or R and R depending on if you are looking at the top of the bottom. (you should be wiring according to the top if you are gas I can almost assure you are a furnace not a heat pump.
it may be fine just someone tried it and cut that jumper. I have the Iris (Ct101 or CT100 same thing) and it works well. I got them to price match Amazon too so that saves $20
