I couldn’t find another post for this so here is a device type for Foscam HD cameras. I started off with the code from @imbrian’s Foscam device and then changed it to work with the HD cameras since the API calls are different and I added some new features and icons. I haven’t programmed in years and this is my first time using this language so there is probably still a lot of cleaning up to do.
I have only tested this with a FI9821W V2 and only HTTP so far.
The following features are available:
Take a snapshot
Toggle the infrared lights (Auto, On, Off)
Enable/Disable motion alarm
Go to and set preset locations
Enable cruise maps
Control PTZ
Reboot
Notes:
-When refreshing the IR mode will only show either Auto or Manual because there’s currently no way to poll for on and off in manual mode.
You need to manually enter the names of the presets and cruise maps in the settings because the API for the HD cameras uses the actual names instead of numbers now.
You can’t change a preset if it is set as your start-up preset.
Gracias. I installed one of these for a buddy and he was disappointed that he couldn’t “arm the motion when he left”. Maybe now I can get that feature to work for him! Can you enable the motion alarm when the mode is “away”?
I added your device type (foscam HD) and am trying to use it with foscam 8918, and although the device shows up in smartthings app with all its buttons, (and I’ve configured ip address and user and pass…) it doesn’t seem to function…any ideas?
@smartthing Try @imbrian’s Foscam device type. My device type only works for the HD cameras which I believe are all 9xxx series. I’m having trouble finding his forum post but here is the link to the code…
Thanks for the link, I couldn’t find it either…so the camera seems to be responding…however, when you click ‘take’ , where does the snapshot go? and also, should it work if I input the local ip address? I have dynamic ip so the local would be much better…
I have this working for two cameras. I have not been able to get my FI8602W working however. The URL to the snapshot is /tmpfs/auto.jpg. Should this device type work with this camera?
@acastal This device type only works with HD cameras. I created a device type that works with the internal IP address for both HD and non-HD cameras you can find in the post above yours. I haven’t implemented external addresses for that yet though. If you need to use an external look for imbrian’s Foscam device type.
@thegibertchan Have you compared the Foscam HD capabilities vs Dropcam? I ended up returning my Dropcam due to the constant motion alerts for window shadows and sun movement. As far as I can tell, you can’t define an alert area unless you are buying their cloud storage. Foscam allows you to record to ftp, local SD card, email pics, etc. I’ve had some issues with Foscam HD cams as well, but a lot more out of the box for 1/2 the price. Hope to hear of progress soon, and specifically which Foscam models. The FI9821W’s are popular, often on sale and good value. Thanks!
