Alexa flash light when timer hits zero?
The IFTTT recipe for Hue is taking advantage of a hue feature that blinks the light. So that’s not available for your outlet.
What you can do is create a virtual switch, have the IFTTT recipe turn on that virtual switch, and have that virtual switch coming on in SmartThings run a smart app that will turn your outlet on and off.
My suggestion for the smartapp to do this would be core. This is a very sophisticated community created rules engine. It may seem complicated to begin with, but there are lots of community members who can help you get it set up and get your rule ( called a “piston” in core) set up.
So it’s going to take a little work to get it set up, but you can definitely do it. :sunglasses:
Talk to the folks in the following thread, and they can get you started:
