OK - so after a few days of observation, there are definitely some oddities with AlarmServer. I have attached a photo to emphasize what I’m seeing. There are constant “zone commands” in the activity feeds of my devices. Am I reporting more activities than I should be from my panel? Ideally, I would only see true activities (zone open/zone closed) and nothing else. Reporting from AlarmServer does NOT seem consistent. I have also attached a sample of the terminal output from AlarmServer. Please let me know if this is the norm when using AlarmServer with SmartThings or if anyone else’s experience has been better. Thanks so much for the help!!
Wed, 23 Jul 2014 15:34:31 DEBUG <root alarmserver handle_zone_timer_dump> Front Door (zone 1) Last Closed 3 minutes, 20 seconds ago
Wed, 23 Jul 2014 15:34:31 DEBUG URL: https://graph.api.smartthings.com/api/smartapps/installations/e825ea34-45a2-420c-9e87-1e9f546e7d9d/panel/610/1?access_token=e14f801b-4952-4a0d-b218-422536b98fbd
Wed, 23 Jul 2014 15:34:31 INFO <requests.packages.urllib3.connectionpool connectionpool _new_conn> Starting new HTTPS connection (1): graph.api.smartthings.com
Wed, 23 Jul 2014 15:34:32 DEBUG <requests.packages.urllib3.connectionpool connectionpool _make_request> “GET /api/smartapps/installations/e825ea34-45a2-420c-9e87-1e9f546e7d9d/panel/610/1?access_token=e14f801b-4952-4a0d-b218-422536b98fbd HTTP/1.1” 200 26
Wed, 23 Jul 2014 15:34:32 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:34:32 DEBUG RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:34:32 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:34:42 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:34:42 DEBUG <root alarmserver lineReceived> RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:34:42 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:34:51 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:34:51 DEBUG RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:34:51 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:35:02 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:35:02 DEBUG <root alarmserver lineReceived> RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:35:02 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:35:11 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:35:11 DEBUG RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:35:11 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:35:21 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:35:21 DEBUG <root alarmserver lineReceived> RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:35:21 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:35:31 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:35:31 DEBUG RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:35:31 DEBUG <root smartthings partitionStatus> URL: https://graph.api.smartthings.com/api/smartapps/installations/e825ea34-45a2-420c-9e87-1e9f546e7d9d/panel/650/1?access_token=e14f801b-4952-4a0d-b218-422536b98fbd
Wed, 23 Jul 2014 15:35:32 INFO <requests.packages.urllib3.connectionpool connectionpool _new_conn> Starting new HTTPS connection (1): graph.api.smartthings.com
Wed, 23 Jul 2014 15:35:33 DEBUG <requests.packages.urllib3.connectionpool connectionpool _make_request> "GET /api/smartapps/installations/e825ea34-45a2-420c-9e87-1e9f546e7d9d/panel/650/1?access_token=e14f801b-4952-4a0d-b218-422536b98fbd HTTP/1.1" 200 None
Wed, 23 Jul 2014 15:35:33 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:35:33 DEBUG <root alarmserver send_data> TX > ^02,
Wed, 23 Jul 2014 15:35:33 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:35:33 DEBUG RX < ^02,00$
Wed, 23 Jul 2014 15:35:33 DEBUG Envisalink response: Command Accepted
Wed, 23 Jul 2014 15:35:33 DEBUG RX < %FF,CBFF0000D1FF00000000000000000000827E3BC9000017E9000000000000000044C80000BFC200000000000047D500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000$
Wed, 23 Jul 2014 15:35:33 DEBUG Front Door (zone 1) Last Closed 4 minutes, 25 seconds ago
Wed, 23 Jul 2014 15:35:33 DEBUG URL: https://graph.api.smartthings.com/api/smartapps/installations/e825ea34-45a2-420c-9e87-1e9f546e7d9d/panel/610/1?access_token=e14f801b-4952-4a0d-b218-422536b98fbd
Wed, 23 Jul 2014 15:35:33 INFO <requests.packages.urllib3.connectionpool connectionpool _new_conn> Starting new HTTPS connection (1): graph.api.smartthings.com
Wed, 23 Jul 2014 15:35:34 DEBUG <requests.packages.urllib3.connectionpool connectionpool _make_request> “GET /api/smartapps/installations/e825ea34-45a2-420c-9e87-1e9f546e7d9d/panel/610/1?access_token=e14f801b-4952-4a0d-b218-422536b98fbd HTTP/1.1” 200 26
Wed, 23 Jul 2014 15:35:34 DEBUG ----------------------------------------
Wed, 23 Jul 2014 15:35:34 DEBUG RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:35:34 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:35:41 DEBUG <root alarmserver lineReceived> ----------------------------------------
Wed, 23 Jul 2014 15:35:41 DEBUG <root alarmserver lineReceived> RX < %00,01,1C28,08,00, DISARMED CHIME Ready to Arm
Wed, 23 Jul 2014 15:35:41 DEBUG ----------------------------------------
