Apologies if this has already been covered. However, is there an easy way to disable the animation that occurs when loading a page? I have multiple dashboards linked together with the first two rows the same across all dashboards. I’d like for transitions from dashboard to dashboard to “appear” as if the same page is loaded.
@Imosenko Have you try this?
http://IPADDRESS/videostream.cgi?user=[USERNAME]&pwd=[PASSWORD] or you try at this website
Just curious how much data does the dashboard using leaving it on 24/7 with no camera tile. I see 430Gigs with firefox on my wall mount tablet in 20 days. There is a link tile to another ActiON with 2 ip cams but I hardly go to that page. Anyone else see this or just me?
I have seen this exact issue with MJPEG cameras from a local Lan (ispy)
Have you been able to identify the root cause or a workaround?
I used chrome inspector to debug this issue and couldn’t identify much useful information. The first six streams load fine while the remaining feeds show pending and never load on the network tab.
No, currently there is no way. Hopefully when I implement the groups, you won’t have to rely on multiple instances.
430 gigs? Are you sure it’s not kilobytes or megabytes? I don’t think your ISP would even be able to put through 430 gigs in 20 days…
The dashboard frequently synchronizes with the back end. If there is no new data, it pulls something like 20 bytes. When there is new data, the response is still miniscule.
I haven’t used my own dashboard on a dedicated device for prolonged periods, but I’m now curious to measure it precisely.
Just saw this … maybe of interest for anyone looking to deploy a few dashboards?
http://dealmac.com/Microsoft-Office-365-w-7-8-GB-Android-Tablet-for-50-free-shipping/1282717.html
Best Buy offers a Microsoft Office 365 Personal 1-Year Subscription for Windows and Mac bundled with the DigiLand 7" 8GB Android Tablet, model no. DL701Q, for $49.99 with free shipping. That’s the lowest total price we could find for items purchased separately elsewhere by $72. (It’s even $15 under the best price we could find for Microsoft Office alone.) The tablet features include a MediaTek MTK8127 1.3GHz quad-core processor, 7" 1024x600 touchscreen, 8GB storace, 802.11n wireless, 0.3-megapixel front-facing camera, 2-megapixel rear-facing camera, micro SD slot, and Android 4.4 (KitKat).
I have a Digiland - It works well for the dashboard part, but I haven’t gotten a way to mount it and be able to turn it on without pressing the power button. It does not have a proximity sensor. If anybody has any ideas on that, I’m all ears.
Thank you for that link. I found one of the camera URLs and will try it tonight.
I have these mounted with my android tablet.
I was able to use two apps that would use the front facing camera and detect motion to turn on the display. But it ate through the battery, so I just hit the button to turn it on now.
I used two Large 3M Velcro strips that you would normally use to hang pictures works great.
It has a front-facing camera.
I followed the instructions on this page:
And got it to work great.
Here are the pasted instructions:
Just to let you know I have some up with a simple solution it combines an app from the app store called Motion Detector by jastrzab: https://play.google.com/store/apps/details?id=org.motion.detector Then install a plugin called Turn Screen: https://drive.google.com/file/d/0B59hfsZAaVYtYndqQzNXWVBkaXM/edit?usp=sharing
Install both apps.
Open the Motion Detector app and turn on “Send” at the bottom of settings. Click on motion detector (at the top) and then scroll down to “camera” and select “front”.
Open the Turn Screen app. click the only button to make it active.
Open android settings, Turn off the lock screen or select “none”.
Change the sleep settings to time out in the desired time.
Turn off Daydream.
Open the app (or home screen) you want to have displayed on the screen when the tablet wakes, and you’re all set! Wait for the screen to go to sleep and walk by or wave at your camera and it will wake it up.
Works great during the day or with the lights on. I’m currently working on an external PIR motion sensor that will allow the tablet to wake in darkness. Simple design so far just uses a cheap PIR sensor and a small led light mounted below the camera. When I walk by the PIR triggers the LED light allowing the camera to see, which triggers motion. Hoping to figure out how to eliminate the LED and just run the PIR directly into the tablet using the headphone jack or USB on the tablet. Suggestions welcomed.
One more option to consider…many people with wall mounted tablets leave them plugged in all the time, either running cable through the wall or using a bit of finishing to cover it or using a mount with power built in.
Dlee,
Would you mind expanding upon how you have integrated Blue Iris with SmartThings? Via a smart app, device type, etc. I would very much like to do this at my house and I am not sure what is the best way to do so. Thanks.
It’s not integration. Just have REST endpoints created to turn on/off switches when a camera in Blue Iris detects motion. In the Camera settings in Blue Iris there is an Alerts tab. Alerts have many options, email, notifications etc, one is an HTTP request. I put the REST URL to turn on a switch in that alert box. Each camera can have different alert rules.
So for example, when Blue Iris detects motion on the camera pointed at the driveway, the alert uses the REST endpoint to turn on my Driveway Sensor virtual switch which turns on my entrance light and Ubi announces “driveway visitor”. I have the virtual switch set via “light power allowance” smartapp to turn off an hour later so it doesn’t spam when we are doing yard work and stuff in the driveway etc. (Or we can turn it off on the dashboard to re-arm the notification if we want to)
For anyone interested, I may have discovered why I’m having the issue previously described. Chrome has a max connections per server limit of 6. This seems to explain why in that browser I’m only able to see 6 camera feeds when using my Blue Iris server URL.
This can be overcome a few ways…
- Use a different browser (Ex. Firefox)
- Create multiple dashboard instances (each with up to 6 cameras)
- Use different URLs/Ports to access each camera
- Limit # of cameras to 6
I’ve chosen a variation of 3&4. I have 6 HD foscam cameras using the Blue Iris server/port. Non-HD cameras are accessed using their respective ip address & port.
Thanks Dlee. I had seen that but wasn’t sure if it was the only way. It is how I have implemented it at this point and it does indeed work.
+1 for more info how you got BI working
See my last post above. It’s just REST endpoints.
I went back and checked the full screen browser I mentioned earlier. It turns out that is running in Chrome. It is a Chrome Web app. Figured out how to create them on desktop as well, you can pin or full screen these HTML5 apps.
That got me looking at Tasker on Android. Tasker now supports Chrome Webview where you can call the dashboard URL within a Tasker scene and it loads and runs like a stand alone Android app webview session. So you can set app settings like real full screen like a video app. That works well, see photo.
So now I have the dashboard loading automated through Tasker. When someone walks in the room, motion sensor turns on a smartthings outlet with tablet charger which triggers Stay Alive (app) to turn screen on, which triggers Tasker to load the scene Android Webview with the full screen Dashboard. The android app Stay Alive keeps screen on and prevents dimming while charger has power. Turns off screen a minute after power turned off. That triggers tasker to kill the Webview dashboard a while after you leave the room, x minutes after motion stops. Repeat with fresh web app load next time you return to the room. No video timeouts while screen is off. I did have to adjust my custom css widths and heights a bit.
I can post the steps over the weekend unless anyone already posted how to do this. This thread is too long to check.
